Builder's Corner Restoration and preservation. Keep them running in perfect shape. What size is your bottom bracket? |
#1 |
I picked up my Fat a few years ago and it came with some Manitou forks that worked wonders on the rolling single track of upstate NY. Well, now I live out west and the rocky terrain just ain't as much fun with my Fat (and, honestly, it isn't as much fun period). I have started transitioning it into my daily commuter and want to swap the suspension in for a rigid fork - I understand that finding a replica is, uh, not cheap so I'm looking for something a little more reasonable. 1" threadless forks are hard to find anyway, but I was wondering if anyone knew of a company that is currently doing replicas (I know Soma used to produce a classic CX fork but discontinued it). Not sure what kind of suspension correction I need or what other measurements might be necessary to maintain the geometry, but any advice is greatly appreciated!
Here's my ride: ![]() ![]() ![]() Thanks! EDIT: After a little more searching, I found this guy: https://www.somafabshop.com/shop/pro...3?category=774 Anyone have any experience with these? Last edited by wondermoose; January 6th, 2020 at 1:17 PM. |
#2 |
That´s a susp corrected 19 in wicked. Fork is the common unicrown. A good replacement would be a vicious cycles 415mm 1in.
wanted: ride time. |
#3 |
#4 |
Found a suitable replacement at the local collective. It's a tad shorter (400 axel to crown) but has been a huge improvement over the old suspension. Once this pandemic business is over, it'll be my daily rider... Not much more I need or want to do to it. The rails on this saddle aren't really suited for the old fixed-angle Syncros posts, but it's actually not uncomfortable at all (at least within my 20 mile roundtrip). Maybe a modern crankset, but that's way down the line. Either of you know what the bottom bracket dimensions are? Or if modern tech is even possible on the mid-90s frames?
#5 |
Chris King and Cane Creek used to do extra thick headset base plates 5-10mm if you can find one. That will take the A-C closer to 415mm and slacken/correct the ‘twitchier’ front geometry. The BBs are std 68mm shells on these. I have a Cook Broa RSR on mine 127mm axle width. Some of the nice BBs are pretty adjustable to accommodate different shells. Great looking fast bikes that ride great. Enjoy
#6 | |
![]() Quote:
That´s not a fixed angle seatpost- on the contrary: you can set any angle you want just by tightening and loosing each bolt. You could have any new bb there since it´s a wicked lite w/ threaded bb shell... but why? Sq tapers do what a BB needs to do. I am on the rigid fork camp as well. Can´t wait to have a rigid fork on my 00 ibis. So much more fun to have a precise feeling from the front.
Tags |
fork, wicked lite |
Display Modes | |
